OMG help
Re: OMG help
I woould have to say WHOA! on banging on the drums - it is too easy to miss and hit the studs/backing plate.
As splatterdog and Petros suggest - penetrating oil (at least ATF) on the studs, in the two removal holes and where the drum encirles the hub - wait a bit and then add the bolts and turn slowly. If nothing happens - more oil and try again. And then try backing off the adjuster (PITA and awkward).
- My tercel:: 1985 SR5
Re: OMG help
We skied Stevens Pass and the skiing was good. I think they are going to get more snow in the next few days which will only improve things. I really enjoyed it.
- My tercel:: None
Re: OMG help
If they were looking at the Fel-Pro valve cover gasket cover part numbers, there appears to be two - one with the semi-circular plug and one without. I always buy the one with the semi-circular plug that goes on the rear side of the head. That would be Fel-Pro #VS50348R. Perhaps this will help clear some confusion.Bluebelles Mom wrote:I tried to buy a new valve cover gasket but they said it could be either of two they had listed and I had no idea which one I needed.
2015 Honda Fit EX "Malachi"
Re: OMG help
You need the semi circular plugs and I'd use some gasket goop around them and some to glue the large gasket down on the cylinder head...this way the job might never need to be done again. Plus there are some rubber gaskets on the hollddown bolts?
Re: OMG help
petros plans on debuting his new rocket-powered skis he put together from an old ford he came across at the pull-a-part. immediately following, he will depart the ski hill in his 4WD terc/submarine hybrid.
FYI, i kid because i love the guy. in a platonic way.
- My tercel:: '86 SR5 6 speed
Re: OMG help
....to retire for the evening in his 100% solar/wind powered house, reading Carl Sagan's "The Cosmos" next to a roaring fire. Wearing a smoking jacket hand made of hemp of course.davidlucasbarnes wrote:immediately following, he will depart the ski hill in his 4WD terc/submarine hybrid.
Re: OMG help
i've been one-up'd! well done, danzo.danzo wrote:Wearing a smoking jacket hand made of hemp of course.
Re: OMG help
Is he wearing that smoking jacket or sniffing a smoldering smoking jacket made of hemp?
Re: OMG help
frankly I perfer fleece, I do not see the strange attraction by old hippies to hemp clothing as anything positive.
Re: OMG help
i'll take a bet that it is definitely NOT the latter.ARCHINSTL wrote:Is he wearing that smoking jacket or sniffing a smoldering smoking jacket made of hemp?
Re: OMG help
Petros im having some crankshaft rear seal leak ok oli just some drops , its a must to repare it? or i can just be cheking oil level and adding weekly oil.
It can cause some damage to other parts?
Re: OMG help
Usually there are no issues with a seal leak, if not too bad, and you keep it topped up with oil. You might try some of that oil stop leak stuff the softens and swells old seals, it might work. I do not recommend anything with any type of "seal conditioner" because it the softens and weakens seals, that is unless they are already marginal, or worse. So give it a try.
The only bad thing about a leak is it could get on the clutch at the rear, or the timing belt at the front, which can damage them, but not usually if it is not a bad leak.
Considering how much work it is to replace a rear seal, I would try the seal conditioner for, at least as a temp measure, until you can afford to get to it and replace it. You could even wait until you need a new clutch and do it then.
Re: OMG help
My sister had one of these wagons and had a rear seal go out....I told her it was still drivable and eventually she gave the car to her son who drove it to Florida and then drove it around down there...said he had a little trouble in the mountains with the slipping clutch though. Yours isn't that bad I'd guess. Just make sure you have an opening below the clutch so the oil can drain and keep the level up in the engine.
