Tilt steering wheel plastic trim NEEDED
While I was in Wash at Petros I picked up a tilt steering wheel but i still need the 2 pieces of plastic trim -one the lowerpiece under the colum that the tilt lever fits into - the other piece of trim is the large piece that goes under the colum that also covers the radio speaker . color doesent matter. I need these 2 pieces to make this swap to look factory. pm me if you have these. Thanks Larry.
- My tercel:: "Bones" 87 SR5 4wd wagon
Re: Tilt steering wheel plastic trim NEEDED
Larry, for what year and model and colour?
83/84 but I think any one up to 86 will work,black would be nice but I can paint them any color Larry freight would be to zip 59701
87 will work also.
- My tercel:: None
Tilt steering wasn't offered until 1985, so it would have to be '85+ and I believe it was an SR5 only option.
2015 Honda Fit EX "Malachi"
In '86, tilt was standard for all wagons, whether 2WD or 4WD and optional on DLX sedans.
- My tercel:: None
I suppose I should revisit my Tercel brochures...
So does anyone have one of these cars at your local junk yard with a tilt s-colum?
Still looking for these plastic pieces for my tilt steering colum, does any one have these pieces?
my 4wd DLX '87 does not have tilt steering—the plot thickens.ARCHINSTL wrote:In '86, tilt was standard for all wagons, whether 2WD or 4WD and optional on DLX sedans.
David,
I have never seen that, of course most of the T4wd I see are SR5, I assumed all Tercels after '85 had it. I thought it was another one of those silly federal requirements to make the wheel adjustable. somehow they think being able to move the steering wheel up and down an inch improved safety. I like my non-adjustable one in my '84, lighter and simple. It is just the right height for me, and I am not that tall. the steering wheel perfectsly frames the instrument cluster. I had once considered changing all over when they had one at the local picknpull, but I could not think of a single reason to do it, at least for me.
Could be a Canada market thing.
My previous turtle was an '86 DLX and had the standard column, my current 86 SR5 has tilt.
