ignition switch
DuB.wEasEl
My tercel:: 83 4wd Sr5
ignition switch
Post by DuB.wEasEl »
With a non functional ignition switch can you get an 85 started? I was thinking jumper from battery straight to starter with the switch on. Or would you have to remove the switch and hot wire it?
83 Tercel SR5
81 Isuzu I-mark, Diesel (42mpg on used motor oil, tranny fluid, fry oil, way oil...)
Re: ignition switch
i bought a tercel once that had a missing ignition (just the part the key goes in)
they were putting a flat end screwdriver in the cavity and twisting it to start
celtglen
My tercel:: 84/2WD/Wagon-stock/311+K miles-original engine/original owner/ no mods
Re: ignition switch
Post by celtglen »
DuB.wEasEl wrote:With a non functional ignition switch can you get an 85 started? I was thinking jumper from battery straight to starter with the switch on. Or would you have to remove the switch and hot wire it?
I've done this a few times---Yes this will work, just takes a minute to turn the starter be sure not to let the starter run too long...its bad for the solenoid.
CG
Re: ignition switch
if the contacts on the electrical part are wearing out, it is possible to pop it open, clean the contacts and stretch the spring to make better contact, and put it back together. If the key cylinder wears out, I had them jam up when the tumblers failed, you just remove the tumbers and put the cylinder back in. I call it my "decoy" lock, looks like a lock but you can put anything in it and it will turn.
