How much hp/tq?
GTSSportCoupe
Post by GTSSportCoupe »
How much power can the Z54F take? Is the Z54F the weakest link in the drivetrain of the tercel 4wd (assuming a larger flywheel and clutch)? Or would the front drive axles be the weakest link?
(I'm just dreaming about future heavy engine modifications ;) )
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
3A-C Power
Post by 3A-C Power »
I wouldn't trust it with much over 100hp with stock gears. I'm working on developing a low cost solution to upgrading the clutch hubs and synchros and that would improve strength. I believe the weak part of the tranny is the clutch hub and locking collar which is built into the gears. I would most likely upgrade the gears as well. Toyota used small synchros and clutch hubs and locking collars becuase the gears and locking collars are one piece, made from the same stock to save manufacturing cost. I would make locking collar and hub units that are bigger and buy standard gears and machine them to press-fit onto the hubs. I'm interested in sourcing high performance clutch hubs and synchros and adapting them to the z54f as that might be cheaper. The gears on the countershaft are cut into the shaft itself, so that's probably a source of weakness. I would make a new shaft with replaceable gears.
GTSSportCoupe
Good to know! Thanks.
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
tercel4wdrules
My tercel:: None
Post by tercel4wdrules »
This is a good reason to install a 90 horsepower 4A-F engine in my opinion. There are many questions about how more than 90 horsepower with stock gears will take its toll on the transmission over time. Hopefully 3A-C Power can help us by making those custom gears and syncros.
2015 Honda Fit EX "Malachi"
Thereminator
Post by Thereminator »
Carlos,is that 4A-F a direct bolt-on carb. model and did you price any? :unsure:
tercel4wdrules
My tercel:: None
Thereminator wrote: Carlos,is that 4A-F a direct bolt-on carb. model and did you price any? :unsure:
Yeah the 4A-F I am talking about is the carbureted 90 horsepower one. It looks like the only hindrance with this engine though is that as far as I know the intake is high and the distributor hangs out far onto the firewall so I guess unless you're really determined to do something like this, then I guess it's just cheaper and easier to transplant a 4A-FE into a Tercel 4WD as your second option from the 4A-GE.
Retroloc1
Post by Retroloc1 »
In the '80 a semi-official team raced the Tunisia rally with Tercels. Two stock cars ans two with the 124hp 16V.
Those with strong engine broke the clutchbell.
One stock car finished in a pretty nice place despite of it's weaky engine.
GTSSportCoupe
Very interesting - thank-you!
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
