A/C compressor not engaging
ok, its 95 degrees & 80% humidity outside. needless to say, i want to get my A/C working. but it seems like the compressor isnt engaging. when the a/c is off, the compressor spins slowly (about once every 2 seconds) wether on, off or econo mode. any suggestions? the fan blows, but it just blows hot air.
1984 2wd wagon, "bottle rocket": http://www.myspace.com/1984tercel
1995 Isuzu TFR-S, "Shorty": no cardomain page yet
ive heard that magnetic clutch is a common problem. my dad says that it may be low on refrigerant, and thats why its not engaging. hmm.. ill test the clutch then the R12 pressure.
Check the sight glass? If you see white...bubbles...it's low. Of course you won't see much if the clutch doesn't engage. You might have lost most R12?
Mine is low but it will cool some...but I don't run it much at all.
