Auto trans info needed
I have an 88 Tercel 4 WD with the 3 speed auto. lately it is sliding out of 3rd back into second with even light accel pressure. I did recently flush the transmission to see if that would help. I am looking for info on troubleshooting this transmission and possibly rebuild info and parts sources. Any information would be helpful
- My tercel:: None
Welcome to the forum! First question... have you adjusted the throttle linkage?
You can find the Factory Service Manual on the main page. It has all info you need, as I doubt there were any changes to the A55F transmission in '88. It is an '85 FSM.
The link for the FSM is here:http://www.tercel4wd.com/1985_Manual.pdf. It is a big file so if you have dial-up it may be wise to use a download manager.
2015 Honda Fit EX "Malachi"
If I remember, I'll try to get some info off AllData tomarrow.
Someone recently had the exact same problem, but he deleted his text and his fix. I seem to remember he dismantled the valve body on his transmission and there was gunk all in the passeges. After cleaning it out the problems all went away.
Might try that before dishing out on a whole new tranny and the trouble of swapping them.....
