Last couple of weeks I've noticed my idle was getting rough and the engine sounded like it was missing. So i took it to work and had one of my Techs take a look at it for me. Supposibly there are suppose to be bushings on the throttle linkage and mine have disintegrated causing a major vacumm leak. Anyway is it worth replacing these bushings or go with a weber conversion? Remember I have 459000kms on this carb. Is it true that the Weber needs 3 psi fuel pressure and our fuel pumps put out 7 psi?
Just waying the options and any input will be very much appreciated.
THROTTLE LINKAGE LEAKING
1985 4wd 493000kms. Semi-retired since 1990 Corolla SR5 4wd purchase. 174000kms.
the part that your talking about it where it hooks up to the rod that attaches to the plate for the cable? Mine has a similar problem, it has a bit of a bad idle and it seems to miss fire and sometimes when accel. it doesnt want to then it just takes off.
Daily Driver:
1988 Toyota Tercel SR5 4WD
3AC 2BBl Downdraft Carb
Project Car:
1993 Honda Del Sol Si
D16Z6 Head/Block
D16A1 Pistons (C/R 12.3:1)
Project Car:
D16Z6 Head/Block
I'd recommend finding out about your emissions laws, how much the repair would be, then thinking about a Weber.
Some good info here re 'bad' throttle shaft clearances
http://www.recarbco.com/technical/shaft ... ances.html
Wayne
Wayne
