Carburetor mount gaskets?
mrdance123
My tercel:: 84 and 85 4wd wagons
Post by mrdance123 »
How many gaskets are there supposed to be under the carb?
Can't find this in the FSM.
But I'm assuming, and have usually found on disassembly, 3 gaskets,
1 gasket below, another above heat shield, the resin heater plate spacer, another gasket, then the carb.
Here's my problem,
the new gaskets from Rock-Auto
seem much thicker than the old brittle broken ones being replaced,
and the 4 mounting studs become too short.
Barely can get the nuts on,
and they won't tighten down using all the threads, to be even with top of mounting studs.
Re: Carburetor mount gaskets?
How thick are they, inchwise?
mrdance123
The ones I ordered from RockAuto are probably as thick or a bit thicker as a credit card,
the original gaskets, brittle torn and peeling off, are much thinner.
There are many choices on RockAuto, maybe I got the wrong ones.
They look identical, the cutouts.
Post by irowiki »
There's thick, thin, and thinner. A carb rebuild kit may be your best bet for finding good fit ones.
larry mcgrath
Post by larry mcgrath »
I'd go to the parts store and buy some longer studs--- double nut the old ones to remove them and install the longer studs----- PUT a rag down the intake manifold hole so nothing gets dropped down the hole and ruines your day Larry
