suspension lift
suspension lift
im looking to do a Barto suspension swap. Swap out rear springs with 90 Pathfinder Springs. Then Swap front Struts with 86 Camry (spring,and top hat). Do i have to use shims , or lower drive line or can i just do a Swap and be done ? Thanks
Re: suspension lift
welcome to the forum, 84terc. i think you can find the info you seek in the FAQ. see question #10. here is the link.
https://tercel4wd.com/forums/viewtopic.php?f=2&t=7442
Re: suspension lift
do not do the camry springs route, you will damage your cv axles and blow out the top seals on the struts. go read the various threads on this forum about lift and you will find much information.
