85 parts wagon found for 87 wagon?
jaydee911
My tercel:: 87 t4wd
Post by jaydee911 »
Hi everyone.
I'm going to look at a 85 2wd auto wagon with a blown engine for parts.
My question is am I going to run into any problems swapping parts over from it to my running 87 4wd sr5 wagon.
I understand that the trans and such are diffrent. I'm more looking at it for the fenders,hood,quarter panels, hatch, mirrors, cosmetic type stuff.
Thanks in advance. :mrgreen:
87 tercel wagon
87 toyota pick up 4" on 33s flat bed
rer233
My tercel:: Multiple
Re: 85 parts wagon found for 87 wagon?
Post by rer233 »
Grille, headlights and qtr panels are different (fuel fillers are on opposite sides.) Front struts are shorter on the fwd and the rear suspension's completely different (along with the exhaust, fuel tank, rear brakes, cluster and combination switch ass'y.) Also the rear seat and cargo cover (longer on the fwd, but it can be cut to fit the 4wd.)
jaydee911
My tercel:: 87 t4wd
Post by jaydee911 »
Thanks rer233!
87 tercel wagon
everything forward of the firewall is identical except the strut length, and headlights, marker lights, bumper and grill as noted above. windshield should be the same, as are the front fenders, review mirrors, window regulator (all of these are worth saving if good).
jaydee911
My tercel:: 87 t4wd
Post by jaydee911 »
Sucks about the quarter panels!
Any way to cut them to fit? What's the diffrence?
87 tercel wagon
2wd has the gas cap on the opposite side as the 4wd because the fuel tank is in a different locaiton.
it is integral to the unibody, it can be removed but your weld is important so you do not weaken the body. You can cut them off and weld them on, you either have to weld over the gas cap door, or just have two filler doors on the car to confuse gas thieves.
