Confirm # for fuel sender
JackWagon
My tercel:: 1986 Toyota Tercel Wagon FWD
Post by JackWagon »
Hi,
I'm looking to replace my fuel sending assembly; the entire unit and I'm not sure I'm interpreting the diagrams correctly.
Is this the correct part number: 83320 19875? I have an '86 FWD DLX wagon with 90k miles
I would prefer to replace the existing unit with a new part instead of rebuilding or repairing.
Thanks
Re: Confirm # for fuel sending
That looks right, I think FWD and 4WD use the same sender but I'm not 100% on that.
I'm not sure you'll be able to get a new part now, but if you do let us know where and how much it was!
The fuel tanks are different between 2WD and 4WD, I would assume the sending units are different too.
Mad_Marx
My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
Post by Mad_Marx »
What's wrong with the old sending unit? There is a thread here on some very easy fixes for common problems with sending units.
viewtopic.php?f=7&p=83943#p83943
JackWagon
Post by JackWagon »
Thank you, I found the thread and have already spent a couple evenings with the sender on my bench. Fuel gauge and low fuel light are operational but the sender is inconsistent even with good connectivity. I had a 1968 Toyota Stout with a bad sender and with this project I'm a little impatient. I think I found a NOS sender that should arrive in a couple days and I will soon know if more attention should be given to the ground wires. Once I receive and install the new sender I'll post up what the part numbers are. Keep in mind, I've got an '86 FWD
Oh where did you find a new sender? How much was it?
JackWagon
Post by JackWagon »
It was a NOS listed on eBay several weeks ago and it arrived last week. It came with the replacement gasket and replacement screws. Cost with shipping was about $50 and I have a working fuel gauge!
What was the part number?
JackWagon
Re: Confirm # for fuel sender
Post by JackWagon »
Here are a few shots of the NOS sender: 83320-19875
Looks like the 4wd one... Will pick one up and if it doesn't work it'll be a spare for the fwd wagon.
MrWrench
Post by MrWrench »
They're available from someone on eBay.
I can't speak for the lifetime usage of them, but I put one in my Dakar Rally wagon project.
https://www.ebay.com/itm/363432708064?m ... media=COPY
1983 AV-II Sprinter Carib.
