Confirm # for fuel sender
JackWagon
My tercel:: 1986 Toyota Tercel Wagon FWD
Post by JackWagon » Sun Apr 12, 2015 12:21 pm
Hi,
I'm looking to replace my fuel sending assembly; the entire unit and I'm not sure I'm interpreting the diagrams correctly.
Is this the correct part number: 83320 19875? I have an '86 FWD DLX wagon with 90k miles
I would prefer to replace the existing unit with a new part instead of rebuilding or repairing.
Thanks
Re: Confirm # for fuel sending
Post by irowiki » Sun Apr 12, 2015 11:12 pm
That looks right, I think FWD and 4WD use the same sender but I'm not 100% on that.
I'm not sure you'll be able to get a new part now, but if you do let us know where and how much it was!
81 Coachmen RV, 70k miles
95 Camry Wagon, 153k miles
04 Camry Sedan, 250k miles
My tercel:: 'Everett' Blue mint 4WD wagon and 'Rocky' 86 4WD Wagon
Post by marlinh » Mon Apr 13, 2015 5:57 pm
The fuel tanks are different between 2WD and 4WD, I would assume the sending units are different too.
Mad_Marx
My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
Post by Mad_Marx » Sat Apr 18, 2015 7:10 pm
What's wrong with the old sending unit? There is a thread here on some very easy fixes for common problems with sending units.
viewtopic.php?f=7&p=83943#p83943
JackWagon
Post by JackWagon » Thu Apr 23, 2015 11:27 am
Thank you, I found the thread and have already spent a couple evenings with the sender on my bench. Fuel gauge and low fuel light are operational but the sender is inconsistent even with good connectivity. I had a 1968 Toyota Stout with a bad sender and with this project I'm a little impatient. I think I found a NOS sender that should arrive in a couple days and I will soon know if more attention should be given to the ground wires. Once I receive and install the new sender I'll post up what the part numbers are. Keep in mind, I've got an '86 FWD
Post by irowiki » Thu Apr 23, 2015 11:30 am
Oh where did you find a new sender? How much was it?
JackWagon
Post by JackWagon » Tue Apr 28, 2015 10:12 am
It was a NOS listed on eBay several weeks ago and it arrived last week. It came with the replacement gasket and replacement screws. Cost with shipping was about $50 and I have a working fuel gauge!
Post by irowiki » Tue Apr 28, 2015 10:16 am
What was the part number?
JackWagon
Re: Confirm # for fuel sender
Post by JackWagon » Sun May 03, 2015 10:17 am
Here are a few shots of the NOS sender: 83320-19875
Post by irowiki » Sun May 03, 2015 11:10 am
Looks like the 4wd one... Will pick one up and if it doesn't work it'll be a spare for the fwd wagon.
