I think that I will easily make it to 250000 miles on this engine. It does leak/burn a little bit of oil, less than a quart per 3000 miles; not enough to worry about yet.
The tranny has some problems in 4wd. That is a problem in the winter in the mountains!
The body (and interior) on this car is nearly perfect, with no rust; if I do make it to 250000 I am planning to drop some money into it as a kind of celebration or something. Exterior paint, rebuild/replace the motor clutch and tranny. I replaced the clutch (third time) at 190,000, so hopefully it will last that long~!
I figure for the cost of the rebuild/repaint I will still have a great little old car for mucho dollars less than a new riceburner from ???
