Paint codes
kitchman
Paint codes
Post by kitchman »
Hello again,
My 86 SR5 is two tone in colors. The predominate color is a light color mint green with blue accents. Where are the color codes for a car on the Tercel?
Thanks again
Re: Paint codes
Re: Paint codes
it is on a sticker on the driver's door jamb. do a search on the topic, there is a thread on this topic with a link to a website called touchuppaint, or some such, that has all the color codes for all models of cars going back some 70 plus years. I have bought paint from them for several Tercel project cars. They mix and put in a spray can for you, for a reasonable price. It matched perfectly every time.
Re: Paint codes
I was looking for that topic Peter but I never manage to find it when I need it!
Re: Paint codes
kitchman
Re: Paint codes
Post by kitchman »
Thanks for the replies!
The only demarcation on the driver's door jamb is a I.D. metal plate riveted on. The only numbers other than the vin, weight, model, date etc. are the numbers ( 16081-B ), which I didn't see listed when visiting the touch-up site?? There is no evidence of there being any other sticker on the driver's door jamb.
thanks again
Re: Paint codes
ARCHINSTL wrote:From just two weeks ago... :wink:
https://tercel4wd.com/forums/viewtopic.php? ... ilit=paint
That is the site I found and linked, but there was another site that listed all colors for every year of second gen tercel in one place!
Re: Paint codes
try passanger side door jamb, some years they are under the hood on the fire wall.
what color is your car?
kitchman
Re: Paint codes
Post by kitchman »
It is a light green with dark blue accents. Tried the passenger side, nothing. Will check the fire wall tomorrow.
Thanks again
Re: Paint codes
color 6J4 light jade metallic perhaps?
kitchman
Re: Paint codes
Post by kitchman »
Ok, getting close found it on the fire wall plate under the model numbers it was after C/TR A/TM as 2Y6H8 which equates to Green Metallic. This being the color what denotes the accent color? Does any know what the C/TR A/TM signifies?
kitchman
Re: Paint codes
Post by kitchman »
Still remain clueless as to how to determine the accent color for this Green Metallic car?
Any thoughts please?
Re: Paint codes
What do you mean by accent color?
kitchman
Re: Paint codes
Post by kitchman »
By accent color I am referring to the areas below the side moldings. These areas on the car are a dark Blue color, every where else is the primary color of metallic Green.
Re: Paint codes
I have an '86 Dealer Brochure and the only two two-tone colors shown are, quoting:
Light Jade / Jade Gray (Interior Gray) and Medium Gray / Dark Gray (Interior Gray).
A possible repaint by PO or OE by dealer?
Look here for all of the color combinations - and tag codes - for Gen II Terc colors. It also shows the two-tone combinations. You can also access the Dealer Brochures for all years.
http://www.toyotareference.com/tercel/1983-1988
