I think you can order it from their website now?
Lemme see....
1986 TOYOTA TERCEL 1.5L 4-cyl VIN Code Q 3A-C
FILTERS
Oil Filter......SDF57
Oil Vapor Filter......N/R
Air Filter......TS59
Fuel Filter......GF124
Fuel Vapor Filter......N/R
PCV Valve......HV111
Trans......TF65
BOSCH SPARK PLUGS
SR5
Wire......B09131
Plug......B4479
DLX
Wire......B09131
Plug......B4479
BOSCH WIPER BLADES
4Wd......
Driver side......B40917
Passenger side......B40917
Rear window......B40913
2Wd......
Rear window......B40917
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......SL
Series 2000 Synthetic 0W-30 Motor Oil
SAE 10W-30 Synthetic Motor Oil
SAE 10W-30 XL-7500 Synthetic Motor Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
Above 10°F......15W-40, 20W-40, 20W-50
Above -9°F......10W-30, 10W-40, 10W-50
Manual Transmission,.....GL-5
All temps......75W-90, 80W-90
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Manual Transmission,.....GL-4
SAE 80W-90 Synthetic Gear Lube
SAE 80W-90 Synthetic Lower Unit Gear Lube
Automatic Transmission.....AF3
Synthetic Automatic Transmission Fluid
Differential, Front .....GL-5
Below -18°C......80, 80W-90
Severe Gear 75W-90
Differential, Rear .....GL-5
Severe Gear 75W-90
Fluids
Power Steering Fluid.....AF3
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3 - Not Available Through Amsoil Click here for more information
Clutch Fluid.....HB
CAPACITIES
Engine, without filter..........3.2 quarts[1]
Cooling System, Initial Fill..........5.3 quarts
Automatic Transmission, 2WD Initial Fill..........2.3 quarts[2]
Automatic Transmission, 4WD Initial Fill..........4.5 quarts[2]
Automatic Transmission, Total Fill
4wd ..........6.9 quarts
fwd ..........4.8 quarts
Manual Transmission, ..........4.9 pints
Manual Transmission, 2WD Wagon..........7.2 pints
Manual Transmission, 4WD Wagon..........8.2 pints
Differential, Front..........2.1 pints[3]
Differential, Rear..........2.1 pints[4]
1. Capacity shown does not include filter. When replacing
filter additional oil may be needed. after refill check oil
level.
2. With ENG automatic transmission operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
3. Final drive for automatic transmission only.
4. Rear diff is for 4wd models only.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission
Fill Plug.....29 ft-lbs
Drain Plug.....29 ft-lbs
CAUTIONS
TRANS/DIFF
To drain and refill the manual transaxle,
follow these steps:
*1* Remove the two plugs on the bottom of
the transmission housing and the one plug
on the final drive between the front axle
shafts.
*2* After lubricant has drained, install
the drain plugs but only tighten the front
two; leave the transmission extension
housing drain plug about seven or eight
turns loose.
*3* Fill the transmission through plug
on the drivers side (2WD) or rear
passengers side (4WD) until lubricant
flows from transmission or final drive
fill hole. Fill the final drive through
the plug on the drivers side by driveshaft
as needed.
*4* Tighten extension housing drain plug.
*5* Install and tighten fill plugs.
SERVICE INTERVAL
<a href='
http://www.amsoil.com/lit/g1490.pdf' target='_blank'>
http://www.amsoil.com/lit/g1490.pdf</a>
From their online store....
It says they ship to Canada, just that the sites prices are US dollars unless you register a Canadian address on their site.
Info on their SAE 10W-30 Synth Oil
AMSOIL 100% Synthetic 10W-30 Motor Oil (ATM)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
11.8
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
66.1
Viscosity Index (ASTM D-2270)
176
CCS Viscosity @ -25°C, cP (ASTM D 2602)
3067
Borderline Pumping Temperature °C (°F) (ASTM D-3829)
<-40 (-40)
Pour Point °C (°F) (ASTM D 97)
-48 (-54)
Flash Point °C (°F) (ASTM D 92)
230 (446)
Four Ball Wear Test (ASTM D-4172 B: 40 kg, 75°C, 1200 rpm, 1 hour, Scar in mm)
0.35
Noack Volatility, % weight loss (g/100g) (ASTM D-5800)
5.5
High Temperature/High Shear Viscosity cP, 150°C, 1.0 X 106 s.-1, (ASTM D 4683), Minimum 3.5
Total Base Number >12.2
Available in various sizes from 1 quart bottles to 55 gallon drums.
This site for pricing on this oil - <a href='
http://www.amsoil.com/storefront/Search ... tegoryID=9' target='_blank'>
http://www.amsoil.com/storefront/Search ... oryID=9</a>
Quick Quote being $5.95 for a 1 quart bottle, and $23.40 for a 1 gallon bottle.
Tranny oil now
GL-5 - Long Life 75W-90 Gear Lube - $7.70/quart or $29.65/gal
- Severe Gear 75W-90 - $9.25/quart or $109.80/12 quarts
GL-4 - SAE 80W-90 Synth Gear Lube - $20.50/1 gal bottle
I think my local Amsoil dealer recommended the Long Life 75W-90. It can go as far as 500,000 miles they are saying. And it is useable in our diffs.
The filters are $10.10 if I remeber right.
