I finally have a used replacement heater valve for the sedan, got it installed, and the darn thing leaks out of where the adjuster goes in and out. Only while the heat is set to "warm" as far as I can tell though
Will it stop leaking after a while, or should I just break down and get a new one? Rockauto has some on closeout for $27
Heater valve leaking
- Gottolovem
Re: Heater valve leaking
If it was me i would buy a new one that's cheep peace of mind.
If it stops leaking(probably won't) you will always have the when will it start leaking again in the back of your mind
you could try some cheap stop leak, it might work. usually it results in a permanent fix if it works at all.
Would stop leak help on a moving part?
it might. or just leave in the "on" position for the winter.
