batt braket
florykitty
My tercel:: 83 Toyota Tercel 4WD SR5,85 Toyota Tercel 4wd SR5,86 Toyota Tercel 4wd SR5 complete for parts,81Toyota tercel SR5 liftback old school
batt braket
Post by florykitty »
looking for oem toyota batt braket ,its that piece of metal that holds batt in place for my 83 t4 wagon,let me know thanks
Re: batt braket
hard to find one of those in good condition, most are pretty well wasted away by now. many cars i see in the wrecking yard do not even have the bracket present.
On mine I found a suitable after market battery bracket and made a adapter for it on the fender side mount. Anodized aluminum and 10 mm bolts, looks cool.
If you are cleaver you could fabricate one from sheet metal too.
florykitty
Re: batt braket
Thanks Petros ,just check today wrecking yard ,but there is no even one in there,86 dlx,85 sr5,another 86 dlx 4wd,everthing but no bracket,
i pick up another sunroof motor for spare and the switch assembly,i go tomorow see what else to pick as spare,well i got to take care 2 tr4 now,so try to fill up my garage shelf for back up.
Re: batt braket
do you just need the hold down bracket or the tray the battery sits in, too?
either way, all '83-'86 tercels will have the same battery tray and hold down bracket--4wd wagons, 2wd wagons, hatchbacks, so check all of them at your local wrecker.
florykitty
Re: batt braket
just hold down bracket assembly and bolts
