4A-C for 83' tercel 4WD WANTED
- My tercel:: 83 4wd Sr5
I am trying to find a 4A-C ready to be rebuilt in the Seattle area.
83 Tercel SR5
81 Isuzu I-mark, Diesel (42mpg on used motor oil, tranny fluid, fry oil, way oil...)
Re: 4A-C for 83' tercel 4WD WANTED
The Lynnwood WA Pick-n-pull shows three corollas of the correct year. None at the Arlington Pick-n-pull.
I have a friend with a 4ac sitting in his garage that he intends to rebuild, the bearings on it are trashed, and it will likely need pistons and rings, etc. we found a good running 3ac to put in his tercel, which is not in it and drivable, and he intended to rebuilt the 4ac and do a swap. But he has been working so much overtime that he has little time to mess with the engine. I will ask if he wants to sell it, it is located here in Arlington.
