Hi again, it's been a long time since I've posted...
Long story short, I came back from being away for over a year, my Tercel is still running, but a bit rough.
Cutting out and spluttering when i try to take off in a new gear, unless i keep it revving up over 2000rpm, then it runs fine.
This resulted in squealing the tyres off the mark a lot.
It has also been backfiring and running on a lot after turning off the motor, which I usually would stop by letting out the clutch with it in first gear.
If I didn't do that, it would run on and on and on until doing a big backwards fart out of the Weber.
Yesterday I decided to check all the Jets were clear in the Weber, did so and yes they are all clear.
Pulled off the Dizzy to see if the vacuum advance breaker plate is moving still, n i'm pretty sure it wasn't, so I cleaned it all up again and put the dizzy back in... not taking note beforehand what position it was in, and just hoping i got it right.
I hadn't, but after moving it one notch the car started.
I took it for a drive and it seemed to be running better at low revs, no more cutting out at take off, but overall it was running with... i would guess about 30% less power than normal. a very strange feeling, and running a little lumpy, but not like one of the leads was disconnected, just a bit lumpier sounding revs, and at idle, a little putter putter type.
So I start thinking maybe I put the dizzy in a little out of line and I should pull it out and try again.
I do that and it wont start anymore...
I do some reading on here and find a thread that explains how to find the right timing with the TDC timing mark on the flywheel and so I go and do that.
But still no starting at all.
It actually makes some weird squeeky (squeeky like air slipping past a valve) pop-like noise when its trying to start. Not a bang-like pop, that I get once every now and then when starting it up again after it's tried to run on and i've let the clutch out in first to shut it up. This noise is different.
I'm wondering if the valves are stuffed completely now, after all the backfires and running on and being run with bad timing... if the valves are stuffed, and it's not getting any compression, could that lead to a complete sudden failure like this?
I just cant think of anything else... why wont she start anymore?
