Thanks all, I think I am going to have them do it with stock bushings. I've done some domestic trucks with poly bushings and it always tightened everything up well...but not this time. I didn't realize the stress it is under, or the importance of the bar. And those bolts are probably on there pretty good.
Wouldn't want to screw it up and use hard bushings only to break the bar at speed.
Sway bar cushion replacement
Re: Sway bar cushion replacement
1986 T4WD SR5 in Beater Blue
