whats the 1986 ter compatable with
i need a new whole drivers side stut asambly for a 1986 terc just woundering what other cars are compatable with it
Re: whats the 1986 ter compatable with
All '83-86 Tercels have the same front strut. Also I think all FWD Corollas of the same year also uses the same strut (they use the same strut cartridge anyway).
dose it matter if the corroloa is twin cam or not?
tried swapping front strut ass'ys between an '84 2wd wagon and an '83 4wd wagon-NOT the same. 2wd ass'y was 1 1/2 to 2 inches shorter. any 4wd wagon should work tho. good luck!
addendum-- i assume you have a 4wd wagon my guess is 2wd wagon and sedan are the same.
yeah i got the 4wd wagon when messuring the struts do u messaure from top to bottom of the whole unit
That is interesting because the strut cartriages are the same. I have found that both Corolla All-trac front strut and the Celica GTS front strut are the same and will fit in the TErcel if you swap out the top mount and use hat shaped washer to change the bolt size at the low end where it bolts to the steering knuckle. It is also larger diameter and has more damping, so you would want to change these as a pair. I have a pair of Celica GTS struts and springs waiting to be installed on my T4wd....rer233 wrote:tried swapping front strut ass'ys between an '84 2wd wagon and an '83 4wd wagon-NOT the same. 2wd ass'y was 1 1/2 to 2 inches shorter. any 4wd wagon should work tho. good luck!
i checked 2 parts sources today (world pac and rock auto) and both came up with the same info- KYB part #s for front strut inserts are- 363037 (4wd) and 363030 (2wd wagon& sedan.) not sure if the strut housings are the same tho. hope this helps.
https://tercel4wd.com/forums/viewtopic.php?f=3&t=3209
This link is shown here as an alternate source for parts, not a disagreement on the #'s shown by rer233. Back in late 2007 it had the best pricing and free freight. Dunno now, though, but worth a check.
