size (mm) of socket needed to loosen rear diff oil bolt to check oil
Does anyone know off hand? I don't want to round it off to much with a adjustable wrench
also is the breather(?... not quite sure) thingy on top of the rear diff meant to be loose?
cheers, Matt
size (mm) of socket needed to loosen rear diff oil bolt chec
- Mattel
Hmmmmm........ I want to say 21mm.... 6-sided please.
In case you decide to refresh the transmission fluid as well - read this before you try:
viewtopic.php?t=2160&highlight=craftsman
- Mattel
thanks fellers.. scared to see what Primordial soup is in that rear diff.. Matt
