THANKS!
Sorry - I should have more explicit.takza wrote:...how do you transfer to Contac paper? Don't get it....
I did this with the TRD logo's on my front fenders (mabey they are called wings down under?) I had the logo on disk, it wasn't exactly perfect, but i just told him the size i wanted and he did the rest, turned out great.Mattel wrote:this logo site I use quite a lot at work as it has high res vector files that you or a signwriter can resize without pixelisation.
This link has the "TOYOTA" text with the 90's onwards logo attached you could download this onto disk, get a signwriter with a laser cutter to make a large vinyl sticker of just the text in white to the correct proportions that you need (measure the old one first obviously).
This would be a clean and cost effective option, the vinyl text will come out really well if you clean the area first I wouldn't bother about the black outline
good luck!
Matt
http://brandsoftheworld.com/search/?que ... _id=114378
I'm with you on DIY and saving the $$, but I've tried contact paper on exterior surfaces...it won't last too long. Vinyl electrical tape will though...you could do lettering of a sort with it. Or other heavier ext vinyl.ARCHINSTL wrote: I did not exact;y "transfer" the letters to Contac paper, but printed the letters on paper, then cut out the letters and placed them on the Contac paper and then cut the letters from the Contac paper.
Mattel's method would be a lot more "permanent" and certainly easier to install, but I opted for the low-tech approach (read: I'm a cheapskate).
Exactly why I'm going to make a stencil and spray it. The edges are curling after about 5 or so months. However, it lasted long enough for me to like the font. I'll take a pix when finished.takza wrote: ...I'm with you on DIY and saving the $$, but I've tried contact paper on exterior surfaces...it won't last too long. .
