Diff jam
Diff jam
When I press the diff lock button, the orange diff lock light comes on. Above 30km/h everything starts banging and shaking. One problem, After switching it off it wont disengage, the light stays on and I cant do over 30.
How do I unjam it??
Help!!
How do I unjam it??
Help!!
AE95 Stock, AE86 Worked, KE70 panelvan with 16psi ZE, Ke20,Ke25
Re: Diff jam
It sounds like your tires are different sizes (different manufacturer, difference in wear, different inflation...etc.). Beware, or something will blow up. You can un jam it by going in reverse very slowly while pushing the button (after you have been going forward). This will un-bind the drivetrain. CHECK YOUR TIRES!!!!!! And don't use your 4wd until you fix the problem.foxtail wrote:When I press the diff lock button, the orange diff lock light comes on. Above 30km/h everything starts banging and shaking. One problem, After switching it off it wont disengage, the light stays on and I cant do over 30.
How do I unjam it??
Help!!
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Thanks
Got in it this morning, light still on. Started reversing down the driveway and it all came good.
Thanks for that.
PS. Diff codes. F5-834. My Ae95 has this, I pulled the axels, and they are the same as S axels from AE86, but much longer. I pulled some from another F5-834 at the wreckers, and they were much bigger, similar to T axels but longer. To me the centre looks like a T but I havent measured it yet.
Thanks for that.
diff lock
WTF!!! have u guys got rear wheel diff lock in your cars????
84 SR5, 4A, 75W Globes, CB Radio, Twin 13" Subs with Twin 750W Amps, Neons, 15" Enkei Rims Fitted With 215 65-15 Tyres, 200000Km on clock, GPS, Hood Scoop and plenty more to come. I love my terc
- Mattel
nope, I think Foxtail has whats known as a corolla wagon down hear in oz. They have the full time AWD set up and a centre diff lock as opposed to our FWD/4WD.
- Mattel
He does mention AE95 a couple of times. either way it probably would do the same thing in either car and lock up the centre diff.
Hey Foxtail, you only need to press that button in snow, really soft sand or where you have one wheel spinning and loosing traction. I really wouldn't use it on the road under normal conditions... It sounds like your car is trying to tell you something.
diff lock
my 1983 tercel has a diff locked rear diff its sik as in clay patches
but the best bit is that in the padock u leave LSD marks everywhere hehe
1983 tercel 13inch speedy mags 185/70/13 tyres pedders heavy duty springs(rear) rebuilding car stereo deck clarion dxz766mp clarion splits on the way kenwood 6x9 rear fill jbl subs 12inch
3/4 done exhaust 2inch monza 4inch tip cannon
au`
yeah im in oz aswell. actually perth W.A . so how does ur corolla 4wd wagon go offroad? i never knew they had centre diff lock. if i had i prolly would have bought one? how do they compare to tercel?
Re: diff lock
...that would be an option with our wagons? Weld the rear diff solid....so when in 4WD only one of the front wheels could spin.jonesy38 wrote:my 1983 tercel has a diff locked rear diff its sik as in clay patches
Might break a rear axle on dry pavement though?
I have heard of a homemade spool with a cable actuator on an old monza.... I'm sure that some sort of selectable locker could be devised, but for what? Kamiphloj seems to take his tercel all over with no locker and no issue. If you NEED a locker to get there, a Terc is probably not the vehicle you should be taking.....
I would have to say that YOU are a better driver than the drivers of those capable trucks, and that those trucks were not as capable as you make them out to be. Out here, I take my wrangler places where the rocks come up higher than the Terc's front bumber. The ground gets pretty muddy and slippery with the "Tillamook Clay" and even a jeep with a 6" LA lift, 35" BFG Mud Terrains and 4.56 diffs and 4:1 t-case with all 4 wheels locked can't seem to make it through without much difficulty. As I have only a LSD in the rear of my Jeep with 31" mudders and factory gearing, and I seem to go almost all the places where the big boys go, I can attest for the importance of the driver's skill and for how well a driver knows their rig. The most common problem I see for 4wd'ers is too much gas = not enough traction. Tires lose their grip from having too much torque applied and not being able to hold their ground.
With that said, the tercel is a very very capable rig; a great balance of power/torque and weight for offroad and loose surfaces. If a Tercel NEEDS a locker, it is probably not the vehicle that one should be out there in. Then again, it would be pretty sweet for a tercel to pull out a stuck jeep...........
Hrm, wonder if ARB's Air Locker for the Toyota pickups would be able to be squeezed into our diffs...
Would certainly come in handy when the county snow plows block the end of my street off. Instead of trying to sail over, plow through!!
1986 Tercel Wagon 4X4 SR5 (sold to splatterdog).
A bullet may have your name on it, but shrapnel is addressed, "To whom it may concern"!!
