Found these rubber mounts for my Tercel Air filter housing. It fits pretty good. Before I had used stacks of rubber washers and it just looked ugly. Now the air filter housing is resting very firmly and probably has less vibration.
Found them on ebay.
https://www.ebay.com/itm/4-Amp-Case-Was ... SwKclZ3svt
Air Filter Housing Supports/Mounts
- My tercel:: 1983 Tercel 4x4 SR5
Re: Air Filter Housing Supports/Mounts
As reported in another thread, the PCV grommets are a perfect fit, and a heck of a lot cheaper!
I've used a short length of small diameter rubber hose split along its length, in a pinch.
I use the regular gromment on the bottom, and some old valve cover washer/gasket on the top, seems to hold it well. I always have old valve cover bolt seals sitting around.
Looks perfectly fit. We might need one for the Tercel, we'll just finish the installation of rack and tonneau covers for the kayak mount on the truck. Thank you for the link.YoYoTercel wrote: Thu Apr 26, 2018 2:12 pm Found these rubber mounts for my Tercel Air filter housing. It fits pretty good. Before I had used stacks of rubber washers and it just looked ugly. Now the air filter housing is resting very firmly and probably has less vibration.
Found them on ebay.
