Air Filter Housing Supports/Mounts
YoYoTercel
My tercel:: 1983 Tercel 4x4 SR5
Post by YoYoTercel »
Found these rubber mounts for my Tercel Air filter housing. It fits pretty good. Before I had used stacks of rubber washers and it just looked ugly. Now the air filter housing is resting very firmly and probably has less vibration.
Found them on ebay.
https://www.ebay.com/itm/4-Amp-Case-Was ... SwKclZ3svt
Re: Air Filter Housing Supports/Mounts
As reported in another thread, the PCV grommets are a perfect fit, and a heck of a lot cheaper!
The Professor
Post by The Professor »
I've used a short length of small diameter rubber hose split along its length, in a pinch.
1975 Subaru SuperStar wagon
1987 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
I use the regular gromment on the bottom, and some old valve cover washer/gasket on the top, seems to hold it well. I always have old valve cover bolt seals sitting around.
Termell
My tercel:: 1985 Tercel
Post by Termell »
YoYoTercel wrote: Thu Apr 26, 2018 2:12 pm Found these rubber mounts for my Tercel Air filter housing. It fits pretty good. Before I had used stacks of rubber washers and it just looked ugly. Now the air filter housing is resting very firmly and probably has less vibration.
Found them on ebay.
Looks perfectly fit. We might need one for the Tercel, we'll just finish the installation of rack and tonneau covers for the kayak mount on the truck. Thank you for the link.
