FS: 3AC motor and accessories
- My tercel:: 1986 Tercel Wagon DLX
I am pulling the motor in 3 weeks or so and would like to get a buyer lined up for this stuff as soon as possible due to me not having much storing space.
Here are the parts I'll have available:
- 3AC motor with 230k miles (very little leaks, running ok)
- 3AC engine gasket kit (brand new, unopened. paid $55 two weeks ago from RockAuto)
- 2 factory carbs (both for parts only)
- Weber 32/36 DGEV carb
- Full carb gasket kit (lower, upper, Weber adapter gaskets)
- Factory carb air cleaner assembly
- Factory emissions system (FED car)
- New alternator with roughly 2XXX miles on it
- Starter
- Distributor with new cap/rotor
- NGK spark plug wires
- Wix fuel filter (brand new)
- Timing belt (brand new Beck Arnley)
- Power steering pump
- Factory steering wheel, grey (9/10 condition)
- DLX gauge cluster (8/10 condition)
The motor will be in Vancouver, Washington and the parts will either be there or I'll be bringing some parts home with me in Portland. If interested let me know.
WILL DO A COMBO DEAL IF YOU BUY MULTIPLE ITEMS
- Starter
- My tercel:: 83 4WD Tercel SR5 - The Brown Badger
Re: FS: 3AC motor and accessories
How much for the Weber?
PM sent.
- Gottolovem
Your not going to put the webber on the 4a or did you get another
I have something else lined up.Gottolovem wrote:Your not going to put the webber on the 4a or did you get another
- Gottolovem
The plot does thicken
Don't look into it too much, it won't be anything spectacular.
Weber is now being held for a member.
The following has been sold:
- TVSV
- Distributor
- Emissions gear
- Starter
- Gasket kit
- Center caps
- Timing Belt
- Fuel filter
- NGK wires
- Alternator
- Starter
- TVSV
- Distributor
- Emissions gear
- Starter
- Gasket kit
- Center caps
- Timing Belt
- Fuel filter
- NGK wires
- Alternator
- Starter
3A was pulled last night. I'll have a lot more parts available soon.
- My tercel:: 88 Tercel Wagon 4wd SR5 6-speed manual
Do you have a working EBCV (11-13 ohm)?
and VSV (38-44 ohm)?
88 Tercel Wagon, 4wd, SR-5, 6-speed Manual
89 Dodge Dakota, Longbed, V-6, Auto
96 Dodge Dakota, Club Cab, V-8, 5-speed Manual
If that is the emissions stuff then it is already sold.geoedb wrote:Do you have a working EBCV (11-13 ohm)?
geoedb- I've got both items- they spec out ok. I assume the fed and calif versions are the same?? Mine are fed. How's $25 plus shipping sound (should be around $13 USPS flat rate.)
Let me know, Rich.
Motor pending sale.
The VSV should be part #17650, or 89570-16070
The EBCV should be part #25730-15010
The part diagram does not show it a different fed vs. CA
Do you have a Jet too? part 23288 (9092504003?)
So I would love these parts!
