My handbrake light warning light stays on
mrmora
My tercel:: 1987 Toyota Tercel Wagon DX
Post by mrmora »
After I start my car and let it warm up for a bit, I release the handbrake and start to drive, but the handbrake warning light stays on for a while and then shuts off. Is this light a multifunctional light, meaning that it also comes on to let me know that the brakes, or fluid level is low? Could this just be a faulty handbrake warning switch?
Re: My handbrake light warning light stays on
Check your brake fluid - NOW!
I don't think anyone has mentioned a faulty brake lever switch.
marlinh
Post by marlinh »
Agreed, it is probably a low fluid situation.
don't drive it until you confirm the brake fluid level is good. if it's low, you need to find where you're leaking brake fluid and fix it asap. you don't want to be driving if you can't stop. my guess is it's probably the rear wheel cylinders but check all the steel lines, rubber hoses, master cylinder, etc--everything.
