old non-working forum links
there are some old links on the forum that will not work due to a server change that occurred a few years ago. if anyone comes across a link on the forum like this:
http://www.tercel4wd.com/forums/viewtop ... 16&p=28985
all they need to do is click that old, non-working link to open it in a new window. it should bring up an 'error 404' screen or something like that. then you can just remove 'forums/' from the URL of that non-working window so it looks like this (minus the spaces—i had to add them so the full URL would show up here):
http:// www. tercel4wd.com/forums/viewtopic.php?f=2&t=3916&p=28985
hit enter, and the link should then work.
- Neu
Re: old non-working forum links
Report the post as well. We can manually edit it.
you're the man, chad. hella thanks for continuing to make this site work, even when you have no terc to call your own. that's dedication!
- Neu
I still love these cars and plan on purchasing another.dlb wrote:you're the man, chad. hella thanks for continuing to make this site work, even when you have no terc to call your own. that's dedication!
We can now unstick this topic. All old forum links will work now that we're back in /forums/
All "new" forum links will work too, thanks to redirection. For example,
https://tercel4wd.com/forums/viewtopic.php?f=2&t=8103 which is posted in the FAQ, will seamlessly redirect to viewtopic.php?f=2&t=8103
Once we do a forum upgrade I'll go through and fix every link, but this will do for now.
I open a lot of the car for sale posts ..most of them are
by gone cars on cl..no longer up.
Just Sayin.
Just Sayin.
Not much we can do about that! That is why whenever I post a CL ad here I try and copy over the text and some of the pictures.
if a car sells, the seller probably takes down the ad. people are just linking to the ads here so they are naturally a time-sensitive thing. if you're looking for another t4, you have to keep checking regularly.
- duragauge
- My tercel:: 1986 Tercel 4WD SR5
Am I correct in saying that the reverse is actually true now? That links without forums/ in them need to be edited to include that?dlb wrote: Fri Nov 15, 2013 12:54 pm there are some old links on the forum that will not work due to a server change that occurred a few years ago. if anyone comes across a link on the forum like this:
For instance,
https://www.tercel4wd.com/forums/viewtopic.php?t=6880
works just fine, but
doesn't.
yeah, the forum has gone through a number of changes over the years so this old thread is no longer accurate.
Ah I need to fix that redirect.
Well I said screw the redirect and just fixed all old links directly in the database!
