WTS: TVSV valves
- My tercel:: 1986 Tercel Wagon DLX
WTS: TVSV valves
I have 3 good condition (physically) TVSV valves that I just pulled from the local Pick-N-Pull. Plastic is in good condition and none of them have broken nipples. I cannot guarantee that they will work but I spent a decent penny for them at the yard and wanna help anyone out that needs one.
$10 shipped for each one sound fair? Will post pictures soon.
- Gottolovem
Re: WTS: TVSV valves
Does that mean that you don't want me to send one to you now
I'll take one! Will send shipping info in the morning.
Gottolovem - I'll still take it. Trying to narrow down a few issues with these damn valves. At this point not sure if it's the valves that are bad or another issue.
I'll let everyone know more as I diagnose things, I don't want to send anyone a bad valve.
testing the TVSV is really easy. only requires a stove, a pot of water, a thermometer, one vac hose, and some pliers to hold the bottom of the TVSV in the water as it heats up.
- My tercel:: 1985 tercel 4wd
Agreed. Simple.dlb wrote:testing the TVSV is really easy. only requires a stove, a pot of water, a thermometer, one vac hose, and some pliers to hold the bottom of the TVSV in the water as it heats up.
Can you explain the process a little more? I'll attempt to try it on these valves.dlb wrote:testing the TVSV is really easy. only requires a stove, a pot of water, a thermometer, one vac hose, and some pliers to hold the bottom of the TVSV in the water as it heats up.
the test is in the FSM on page 110, or EC-22.
One of the valves broke in half on me after putting it in the car so I've got 2 leftover.
If you want one let me know.
Pictures of both valves remaining.
Got these 2 valves still. If you want one then send me a PM.
Just an update, I ran both of these on my car and they checked out fine.
I'm new to the sight and interested in a TVSV valve. Do you still have 1 avail? How much do you want for them?
I have a 1984 Tercel Wagon and need this part.
Thank you,
Kip
Thank you,
Kip
Turns out these were all bunk. Sorry for those that were interested.
