THEY DO EXIST
- Gottolovem
THEY DO EXIST
After six plus years of searching for everything t4 in northern Nevada. I walk into pick&pull today there it is a 1988 t4 and yes the elusive cup holders do exist.
Re: THEY DO EXIST
Of course, access to the radio is then limited, and then the same for a smoker...
A better resolution: https://tercel4wd.com/forums/viewtopic.php?f=7&t=1518
Re: THEY DO EXIST
the automatic t4's have stock cupholders but the manuals do not. they get in the way of the shifter, unfortunately.
- Gottolovem
Re: THEY DO EXIST
Odd it fits in my manual with room to spare for shifting. Unable to upload photo for some reason.
Re: THEY DO EXIST
I beleive the 2wd Trecles also have a cup holder. I took one of those pictured out of a 2wd Tercel seeing if I can adapt it to work in the 4wd one. the tunnel is smaller in the 2wd and that center console is taller. I do not recall that it was automatic trans or not. I still have the slide-out cup holder if anyone is interested.
- Gottolovem
Re: THEY DO EXIST
I would like that cup holder do you still have the 2 sheet metal straps that go from stereo to cup holder I noticed there not the same as stereo to little compartment. No mater I can fab one up pm me with price and I will send it
Re: THEY DO EXIST
crazy, i'm definitely interested in pics. i remember taking a look at it once and it seemed like the shifter would hit the cup holder when it was pulled out. i think another member found that too. maybe you mounted yours differently so i'd like to see.Gottolovem wrote:Odd it fits in my manual with room to spare for shifting. Unable to upload photo for some reason.
i modded a cup holder to fit in my 4wd corolla by cutting the shelf in half, and drilling new holes in the metal frame that the shelf and holder mount in. it worked out really well. the 2wd corolla wagons have a different style of cup holder but it's flimsy and is prone to snapping so i used the other style that i found in a corolla GTS.
- Gottolovem
Re: THEY DO EXIST
I have posted many photos in the past including this morning.
Now I keep getting unsupported file has something changed in the last few hrs.
Re: THEY DO EXIST
don't think so, i had no problem posting those pics above. if your pics are hosted on flickr or photobucket, maybe make sure you're using the 'direct' code.
if you're uploading pics on to the forum's server, are the pics the right format? i would guess jpeg's are the preferred type.
- Gottolovem
Re: THEY DO EXIST
http://i1016.photobucket.com/albums/af2 ... 1382845490
Don't know what is going on with uploading photos here is a link of a few photos of the 88 t4 at pick&pull and cup holder after install in my t4.
Re: THEY DO EXIST
dlb - I guess I'm dense, but - where is the radio in the All-Trac?
Re: THEY DO EXIST
in all tracs, the stereo is up top in the center. much easier to fiddle with than in tercs.
gottolovem, that looks great. did you move the stereo down lower on the stock bracket, or did you have to swap the bracket along with the cup holder?
Re: THEY DO EXIST
If anyone ever finds one of these cup holders let me know!
- Gottolovem
Re: THEY DO EXIST
The cup holder was a direct swap the metal dash brackets are diffrent on the 88 it holds the stereo below the cup holder.
- My tercel:: 1986 Tercel Wagon DLX
Re: THEY DO EXIST
Dang I could use one of those.
