gasket??
Carguylen
Post by Carguylen »
Is there supposed to be a gasket on the small metal tube going fron the water outlet housing to the water pump?
GTSSportCoupe
Post by GTSSportCoupe »
Carguylen wrote: Is there supposed to be a gasket on the small metal tube going fron the water outlet housing to the water pump?
There should be an o-ring on each end. Mine is leaking right now...gotta replace the o-rings.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Carguylen
Post by Carguylen »
right after I wrote, I found it, walked to the hardware store, and found one. No more leak. Horray!!
shogun
Post by shogun »
remember there are different materias for orings the best in that aplication are silicon o rings, highest temp rating
dug320
Post by dug320 »
That O-ring is a real pain. The ones in the hardware store will fit. If you are lucky it will last until you change the thermostat. My temporary hardware o-ring lasted 2 years.
