Turbo Tercel
Lateer
Post by Lateer »
Check this out, ladies and gentlemen.
I can see a serious Turbo 3A-C in the near future...
Gasoline Fumes
Post by Gasoline Fumes »
That's way too small for a 1.5L engine. Unless you use four of them! :lol:
I've seen that turbo before, I want one on a go cart. :D
WD8CDH
Post by WD8CDH »
What is it from? Where can I get compressor maps for it?
Thanks
Ron
shogun
Post by shogun »
for the 3ac a small turbo could be a ct9 (toyota) it will work up to 1 bar (14.7PSI) and spool up at very low rpms 2000, one that can be less of a hassle to find is a colt turbo, its a tc04 and itll work like stock with your engine, if you want to go twin turbo yopu can use charade turbos or chevy sprint turbos.
Lateer
Post by Lateer »
I was talking to a mate of mine who's a mechanical engineer and he thought a turbo chainsaw was a nuts idea.
Not only do you have the engine running so fast, but the turbo gets hot enough to give you third degree burns.
And wouldn't it give a little bit of a boost? I'm not talking huge, but enough to be noticed...
And the image comes from <a href='http://www.mjmturbos.com/' target='_blank'>http://www.mjmturbos.com/</a>
Gasoline Fumes
It will make boost, but will choke off the power really early. Look at the size of the exhaust inlet. All of your exhaust will have to squeeze through a hole about an inch in diameter. You might not make any power above 2000 rpm! Plus they're not cheap. I think I remember seeing a price of about US $2000 somewhere. :o
I'd look for a junkyard turbo from maybe a 1.0 to 1.8 liter car. That would probably be pretty close to ideal for a Tercel.
shogun
Post by shogun »
yo could go for a twin turbo for rock crawling, low rpm torque
20vtercel
Post by 20vtercel »
It is not the "smallest" turbo ever made. There is a japanese manufacturer of R/C components that made a turbocharged .21 cc r/c engine. It produced massive power (realative of course). The same company also produced a .15 and .27 rotory engine for use in r/c vehicles.
I just wish i still had that image...... :angry:
Toyota's_Abortion
Post by Toyota's_Abortion »
I have a brand new IHI turbo thats the same size as the middle turbo in the group picture. It is meant to go on a 4 cyl Ford (2.3l ?).
It would probably be a good fit for my Tercel.
Sould have bought a Datsun!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
