Tripmeter broken
- My tercel:: 1986 SR5
Tripmeter broken
Searched in vain for any guidance on repairing my tripmeter. Speedo and odo work fine, but tripmeter does not budge. When I bought the car I noticed it not moving. I then reset it to 0 miles, and it never moved off that. Thoughts?
- Mark
Re: Tripmeter broken
That happened to me on my '83 hatchback. When I took the gauge cluster apart I found a small piece of plastic from the trip counter assembly broken off. I tried gluing it back on, but it wouldn't stay stuck. I then tried using some JB weld to re-create the broken-off piece of plastic. This sort-of worked, but the trip counter was unreliable and wouldn't match the odometer. It often gets stuck. I just left it for now. If it happened on my wagon I might look into repairing it further or try replacing it with one from a yard.
easiest to just replace the cluster assembly. as the tiny plastic parts age, they become brittle and tend to break off. No way to fix it after that happens.
Thanks for the insights; kinda what I expected. I do have a spare cluster that came with the car, so I'll try it out.
