I'm new here and need advice. What toyotas share the window regulator with
the tercel wagon?? I went to picknpull and pulled off a bunch of door panels and can't find one that is the same. The only wagon they had has the same bad regulator. Yes I tried lubricating mine but the gears are just too stripped to
work well. I go back tomorrow to search again and will post my findings if nobody
knows.
thanks.
window regulator
Tercels are the only ones I know of that have the same regulators, but they don't have to come from wagons. 83-86 hatchbacks will work as well.
If you can't find a good regulator, I'll see if I can find one here. Sometimes you have to look through a lot of bad ones to find one good one. I just replaced both of the front regulators in my 86, and pulled, cleaned, and lubed the rears.
