larry mcgrath needs the part in the square in the photo.
Toy calls it "Pin, package tray trim hinge" -
Also used on the following:
Part 64395-16010 (PIN, PACKAGE TRAY TRIM HINGE) was found on the following models:
Date range Model Frames/Options Found in diagram
08/1979-06/1982 TOYOTA TERCEL AL1*(Z) 64-04: DECK BOARD & DECK TRIM COVER
08/1982-12/1987 TOYOTA TERCEL AL2* 64-04: DECK BOARD & DECK TRIM COVER
08/1983-06/1987 TOYOTA COROLLA AE86 64-04: DECK BOARD & DECK TRIM COVER
08/1985-07/1987 TOYOTA CELICA ST16* 64-04: DECK BOARD & DECK TRIM COVER
08/1987-07/1989 TOYOTA CELICA ST16* 64-04: DECK BOARD & DECK TRIM COVER
Send a PM to Larry if available.
I had to post this, as I could not send the photo to Larry in a PM for ? reason.
I found the photo in an old thread started by member dcn, however.
►► Left-click to enlarge ◄◄
►►►At least - I think this is the piece Larry needs - also see http://www.villagetoyotaparts.com/showA ... eLine=5976 Click on full-size image ◄◄◄
Luggage Cover Pin Needed
Re: Luggage Cover Pin Needed
Thanks Tom: Larry
