Door hinge lubrication
donnkirkland61
My tercel:: 85 tercel sr5 4wd wagon
Post by donnkirkland61 »
Does anybody have a good lube in mind for the hinges on the doors? One that will stick arond for awhile? Thankyou in advance.
TURTCEL
Re: Door hinge lubrication
Post by TURTCEL »
There is a Dupont spray lube with teflon that is recommended by members. Check out under 4wd repair questions title....
I use white lithium grease.
https://tercel4wd.com/forums/viewtopic.php?f=4&t=8719
Peace
the dupont silicone/Teflon spray lube is for the plastic and rubber parts of the door and window mechnaisum. for the metal parts of the door, including the hinges I also like the lithium grease, there are also some graphite dry lub that is also good. Regular oil lube works too but attracts dust and dirt that will hasten the wearing out of the hinge pins.
