Here's how it happened. Currently mixed conditions on the roads, with packed snow turned ice on less used roads, and bare wet pavement on main streets. Approaching the intersection of my icy side street and the bare main road, I shifted out of 4wd (which was necessary to make any progress on the side street) to 2wd (since it should be plenty on the bare pavement). When my opportunity came to enter traffic I began turning onto the bare pavement from the last of the icy surface and the tires were slipping a little as the car started to move forward. When one front tire arrived at bare pavement, there was a soft pop and then no more power at the front wheels. I pushed it off the street and began investigating. Once upon a time I had an old Subaru that had CV shafts that would eat through splines at the front hubs, and when that happened I discovered I could just put it in 4 and drive home in RWD (you could watch the axles spin in the hubs if you rolled down the window and craned your neck a little
Drove it home 11 miles that way with out any problems, suspicious noises or any other clues. Thought maybe a linkage on the 4wd shifter popped apart or something, since it is now much easier to put into the 2wd detent, but with some investigation in the manual that isn't possible-- its basically just a lever activated clutch for the rear drive shaft (right?). Failure of the connection between the wheel hub and axle seems very unlikely and on inspection doesn't appear to be the case. Visually the halfshafts look normal, both CV axles are relatively recent replacements (approx. 1 year ago) and it would seem that there have been some noise or other indication that they were set to fail. Flywheel through clutch is fine, clearly, and I'd think the transmission is ok too since it seems to work normally.
I looked through the posts here and it appears this has happened to others a time or two but the OPs never followed up when(if?) they solved or even identified the problem. Any ideas? Shouldn't a front diff failure be accompanied by noise/grinding/lockup instead of a gentle pop? Is there a shear pin? Maybe I just go straight to the front diff cover and have a look?
The Subject: "Pino" 1987 4wd, 179K miles, 5spd, barto lift
