ANYBODY need ?? inclinometer/blue plaid? or anything?
- My tercel:: 83 4ac
there is a sweet tercel in the pick and pull right now, if i had the blue plaid interior it wouls all have already been in my car, this one is really nice if anyone out there needs blue plaid seats, or the interior of sorts, or an inclinometer?? just saying its tough to watch this one die!
Re: ANYBODY need ?? inclinometer/blue plaid?
does it have a tilt steering column ? If so I need the plastic trim around the steering column and the piece that encloses the speaker under the column. where are you located? larry:
larry, if it has an inclinometer it must be an '83 or '84 and from what i've gathered so far, it appears tilt steering wasn't available until '85.
someone on this forum must have a spare driver side lower dash trim piece from a T4 with tilt steering. throw larry a bone and send it to him already!
tercelebr8, you should see how much the wrecker wants for the inclinometer. if it's not overpriced, you could probably turn a small profit flipping it here, or better yet, ebay.
how do u disconnect the inclino? (and larry im buying a parts 88 for 1hundo i hope it has this piece for ya)
if you're just ripping an inclinometer out, it's easy. remove the glove box (two screws at the bottom of it) and stick a socket driver or tiny ratchet with an 8 mm socket up underneath the inclino. undo the 3 nuts but try not to drop them. now you can lift the inclino up off the dash but the wires are still plugged in. you can either pull the wires up through the dash and try to unclip the plug, but the best thing to do is reach in through the glove box area and cut the wires on the car side of the plug with as much of the wires as possible. this is because the car side wires match the colours of the wires that people will need to splice into when they install the inclino in their tercel—just makes the job a little easier.
- My tercel:: 1988 SR5 Wagon
I'm interested in that inclometer if you end up putting it for sale
2JZGTE-powered Tercel SR5
I hope your right.
Re: ANYBODY need ?? inclinometer/blue plaid? or anything?
Grab the inclometer NOW! some creep will get it and put in on ebay anyway (might just cut the wires), might as well get it and share it with others on the this list. Someone here will get it, it is a sure sale.
- My tercel:: '88 Tercel SR5 4wd
I'd be interested in the inclinometer as well if you haven't already sold it. It will match my blue plaid interior that I have out of an '85
Please PM me Tercelebr8
sorry 4drvip snagged it!
