Hello,
I'm looking for one (preferably two) working TVSV.
Need a TVSV
Re: Need a TVSV
a few years ago i hit all the local wrecking yards looking for TVSV's
I found one and it tested good
paid 2.00 for it
last year i found two on Tercel sedans with sideways mounted 3AC's (only one tested OK)
its in a different location
they are located on drivers side (backend of engine) above the tranny
take a wire cutter to cut the Vac lines and a 19mm open end wrench along and a 17mm open end to remove other units next to TVSV
that way you will be less likly to break the TVSV if it is really tight
also if the TVSV tests bad it can be fixed sometimes
i did a write up on how to do it (its somewhere in here)
paid 2.00 for it
Re: Need a TVSV
Hey xirdneh,
I'm going to check for the write up you mention.
Thanks!
Thanks!
