1985 SR5 4WD Tercel gray - $500--Phoenix AZ
stevenstercel4wd
My tercel:: 1983 SR5 stock
Post by stevenstercel4wd »
Don't look to bad looks ac equipped and minimal rust but there is sun faiding and it needs an ignition switch installed. I would like to get it, but I'm moving to spokane wa in about 3 weeks and already taking a truck so I'm goin to have to loose out on this opratunity.
Phoenix, AZ
http://phoenix.craigslist.org/nph/cto/3142633220.html
Re: 1985 SR5 4WD Tercel gray - $500--Phoenix AZ
looks like a great buy, easy fix as well. the new parts alone are worth that much, new battery too! Someone should get this before he guy sells it to the wrecking yard.
I would consider flying down there and getting it, and drive it back here, but I can't right now.
DuB.wEasEl
My tercel:: 83 4wd Sr5
Post by DuB.wEasEl »
Got a buddy in AZ I am trying to talk into it! Can you put the key to on and jump straight to the starter?
83 Tercel SR5
81 Isuzu I-mark, Diesel (42mpg on used motor oil, tranny fluid, fry oil, way oil...)
DuB.wEasEl wrote:Got a buddy in AZ I am trying to talk into it! Can you put the key to on and jump straight to the starter?
sure you can, it is an easy reach to the contact in fact. Or just roll start it. Drove one of Tercel4wdrules T4wd to Seattle that way, the battery had a dead cell and would not start. Each gas stop I positioned the car for an easy push to a down hill roll to restart each time. made it home and bought a good battery from the wrecking yard for $20. and sold the car.
DuB.wEasEl
Had to bump start the i-mark for a while after the glow plug relay fried.. Now she has a button on the column, 12V direct to the glow plugs. Starts every time...
83 Tercel SR5
