I have a 86 front-wheel drive wagon with a 5-speed standard transmission.
Well, I did.
Now it's a one-speed.
Second Gear, to be exact.
Looking for 2WD std transmission in WA
Re: Looking for 2WD std transmission in WA
where do you live?
i may be able to get one
- My tercel:: 1985 SR5
I am in Seattle.
I haven't seen any 2WD Tercel wagons or hatchbacks at pickandpull up in Lynnwood or Arlington for a couple months.
I have my 2WD automatic oil-burner working and I am hoping I can put off the transmission transplant on the other wagon for a couple months.
I am also contemplating swapping the good 86 engine into the automatic wagon.
Right now, I am hoping to run the blue wagon for a couple months and rest my back and stuff.
- My tercel:: 84/2WD/Wagon-stock/311+K miles-original engine/original owner/ no mods
I too have a FWD that was burning oil until I did an engine flush to clean the crap off the valve seals and started adding bardhal (4oz) No smoke to my oil changes. Both made a huge difference and really slowed the oil use..just and FYItercle wrote:I am in Seattle.
I am also contemplating swapping the good 86 engine into the automatic wagon.![]()
- My tercel:: 1985 SR5 4X4
I have one out here in CA..
look up "www.picknpull.com ," I find it more Tercel available than at Canada . I once a while go there at Alington , I just hope there will be at Bellingham ,WA one day .
Thanks, VVMan.
I pulled (picked?) one at pick n pull last weekend.
