85 Toyota Tercel SR5 4wd wagon with 6speed manual.
Car is in great shape for its age, does have a little rust-through in the rockers, but that is all the rust I can find. Car has 332k miles and still runs/drives great. I have been driving it back and forth to work with no major problems... Even the A/C works! The interior is very clean and even smells good. All doors open close solid, all glass is good and windows roll up/down well. Only issues with the car I have found are it needs control arm/sway bar bushings, but I have them on order from Toyota and they come in on Monday, will try to install them Tuesday. And sometimes the A/C makes a ghostly howling noise from the vents when its real hot outside and its been running a while. Also. the choke may need some attention as it takes a few revolutions and a few pumps of the gas pedal to start, but it does always start and run well after that. And lastly, once in a while the car stalls when the A/C is on, but only with the A/C on. With that said, it is a great little car, and a rare find this clean. Car has brand new tires and the brakes are newer per the PO, thay stop great and the E-brake holds well even on hills. Clean engine compartment with all original emmissions equipment in tact, car is 100% original to my knowledge. Has not leaked any oil in my driveway and is clean underneath. Also has new exhaust.
I would drive the car hours away with great confidence, and would love to keep it but somethings gotta go or my wife will leave me.
Will answer any questions via phone @ (704) 264 5356 if you would like.
Clean open NC title.
Car is located in SW Charlotte NC/Ft mill SC area.
$1400.00 cash, no trades please.
Thanks! Kyle
