FOR SALE 83 TOYOTA TERCEL 4WD WG - $700 (OLYMPIA WA)
GLet71
Post by GLet71 »
You have to wait for the tittle to come in. Yes, I said tittle.
http://seattle.craigslist.org/oly/cto/2977671068.html
Edit: This is a re-post, but came in under a different CL community. Sorry for the redundancy, I should have recognized the grammar!
Currently:
Formerly:
Re: FOR SALE 83 TOYOTA TERCEL 4WD WG - $700 (OLYMPIA WA)
Based on the description, and the location, that Tercel appears to be one that I test drove about 4 months ago, I had considered it for a project. If it is the same one, the passenger side B-pillar was dented in, miss-aligning the hinges, not allowing the rear door to close at the top. door was also badly creased. It could be fixed, but will take some welding and a new B-pillar from a wrecking yard. Otherwise it would be a decent project car and well worth fixing. AS it is the transmission is the only reason to buy it, and a set of factory alloy wheels.
