IS THERE A LIST OF COMPATIBLE 13" & 14" RIMS?
Not sure how to upload photos of what rims/wheels on our stock '87 4WD wagon. Wife wants to lose the stock rims/wheels and upgrade to something "aluminum or chrome" - imagine that!!
Re: IS THERE A LIST OF COMPATIBLE 13" & 14" RIMS?
there are tons and tons. the bolt pattern is 4 x 100 so anything with that pattern will bolt on and there's quite a bit or room so you don't usually have to worry about spacers. lots of toyota, honda, acura wheels...lots of the new small cars are compatible too. i like the ford focus wheels so i'm waiting to find a cheap used set from someone ricing out their focus. it might look ridiculous on a tercel but i'll give it a shot.
Dlb,
Thanks for the reply.
Enlighten me. Do you mean any 13" or 14" wheel that has a 4 x 100 pattern would bolt up?
Thanks,
Housewiz
Thanks,
Housewiz
As long as the bolt pattern is 4x100 and the hub is bigger than 54.1 you can get hub centric rings to make the wheel fit.http://www.justforwheels.com/hub-centric-rings.jsp
these are the wheels I have, but mine are 4x100, the ones in the picture have 5 bolt holes.https://tercel4wd.com/forums/viewtopic.php? ... tric+rings Came off my 1986 VW quantum syncro wagon and the hub rings I got from justforwheels.com and the rings fit perfectly. Brought the hub dia. hole from 57.1 (vw wheel) to 54.1 (tercel hub).
There is a very lengthy list from back in '04-5 detailing 14" wheels which will fit - I think takza did it.
