windshield model x-reference?
dirklc
My tercel:: 1984 Tercel 4WD SR5
Post by dirklc »
The windshield in my 1984 is cracked and will need to be replaced (also need to address some rust around the windshield but will save that for another post). I am hoping to source a JY windshield but unlikely I will find an '84 tercel here in Cincinnati. Any other vehicles with an identical windshield (e.g. Corolla or Nova from the 80's)?
Thanks,
Dirk
1984 Tercel 4WD SR5
1985 Range Rover
1998 Toyota T100 4WD SR5
1995 Toyota T100 4WD SR5
Re: windshield model x-reference?
Go to http://www.toyotapartszone.com/ as supplied by member garyfish.
You can enter our car and navigate and get the part numbers and then go to another Toy model and find its part numbers and compare. You might also go to Butler Toy's site and explain what you are looking for - they are in Indy and may have a Cincy source for you. Butler's is www.toyotaoemparts.ciom.
the local auto glass shop around here can get them
have you checked with one?
dirklc
Post by dirklc »
Thanks for the advice, guys. Looks like all the 1982-88 Tercels use the same windshield PN.
I ran the online quote for Safelite and came back @ just over $200 including labor in my area. I suspect that does not include the gasket/molding (which I'm sure I'll need) but that still seems like a deal especially when I compare to the price for the OEM glass @ the dealer for $500 or more.
I'll need to prep the body b/c of the rust around the windshield but - if the online quote is real - then I will probably go the professional route for the install.
1984 Tercel 4WD SR5
1985 Range Rover
