Fresh Horses
Mad_Marx
My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
Fresh Horses
Post by Mad_Marx »
Been a while since I checked in, thought I'd share. Terc II 3AC build pics. Ported/Polished and port matched head/intake/exhaust. New valve springs, re-grind cam from Delta-Cams (mild performance grind). Head shaved .040, engine bored .020 over (and fresh internals to go with it), balanced rotating assembly, fresh freeze plugs, and my machinist even managed to save my block heater.
Looking forward to the engine swap. I'll have a spare 6-speed and 3AC for sale soon.
M_M
andrewrenow
My tercel:: 84 tercel 4wd sr5
Re: Fresh Horses
Post by andrewrenow »
That's freaking beautiful! I wish my motor was that nice.
1984 tercel 4wd sr5
1997 subaru legacy outback awd
1992 toyota paseo (daily driver)
1993 mercedes 190e (for sale)
looking for a corolla all-trac wagon
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
Thanks! It's a labor of love, countless hours of tedious work :)
celtglen
My tercel:: 84/2WD/Wagon-stock/311+K miles-original engine/original owner/ no mods
Re: Fresh Horses
Post by celtglen »
A thing of B E A U T Y
Re: Fresh Horses
Nice. Are you going weber as well? what about header/exhuast? tell us, tell us please!
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
Yes to the Weber, no to the header, but I will be installing larger diameter exhaust pipe, high flow cat, and muffler out the back. Also planning on an MSD 6A upgrade :)
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
Update on engine swap, the current state of things.... still cleaning parts and moving bits from the old motor to the freshie.
Re: Fresh Horses
Nice work. All that port cleaning might get you a hp or two. :-(
celtglen
Re: Fresh Horses
Post by celtglen »
OMG, that is SO BEAUTIFUL! How much did this cost you?
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
I did all the head, intake, and exhaust work myself with a $60.00 kit from standard abrasives. It was $200 to have the head milled, pressure tested, re-surfaced (shaved) and valve surfaces re-ground. He threw in flow testing the head/intake/exhaust for free to verify no significant variance between flow rates on any of the cylinders. $40.00 for a set of new valve springs, $50.00 for a re-ground (street grind) cam from Delta Cams. The parts and labor for all the block and rotating assembly work came to $1,000.00 including balancing the rotating assembly, machining the fly wheel, wrist pins, all the engine gaskets, new oil pump, and a case of break-in Oil. The rest of it was just hours and hours and HOURS of scrubbing rust and goo off 26-ish year old Tercel bits, literally cleaning with q-tips and toothbrushes when I needed to. and re-finishing for assembly. I still have the engine compartment cleaning under way more pics to follow. This build wasn't intended to be a horsepower build. I use my Terc for a daily and a road trip rig, so I was going for efficiency and reliability, the things a well built/maintained T4WD excel at :D
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
Tonight's fun, cross-member redux...
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
...and painted the markers on the timing belt cover...
Re: Fresh Horses
are you flat or gloss blacking all of these parts, rattle can style? i love it, looks slick.
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
I use rattle-can stuff, a base coat of the rustoleum metal surface paint, all weather stuff, then a few coats (again rattle can) of a satin finish stuff I picked up at Napa.
Mad_Marx
Re: Fresh Horses
Post by Mad_Marx »
Going back together (finally) a few pics of the trans....
