Parts wanted
- My tercel:: 1988 4wd wagon
Parts wanted
I am seeking a pair of these braces with bolts (right and left), illustrated by the attached photos. They are on the front end below the front axles. They are 5/8" or 3/4" in diameter and 18" long made from a mild steel. Let me know if anyone can help with this. Thanks. Ned Whiting
Re: Parts wanted
ned, are you still looking for these? send me a PM if you are. shipping won't be cheap from BC, canada to maine but if you haven't found them elsewhere i could pull a pair off of my parts car.
Re: Parts wanted
I could likely find some for you locally here, and even though the shipping is the same distance it would be far less costly from here. However these are simple parts made from light weight tube stock, it seems a local machanic should be able to fabricate some for you out of electrical conduit or if you want to go first class, stainless steel tub stock (never will rust through again!).
