Can any one with a Weber take a pic of the fast idle cam/choke cam linkage between the choke housing and main body and post it? I was doing the rebuild and the shaft popped out and everything scattered to the four corners of the shop and I'm not sure how it goes back together. I've check the Weber parts diagrams and none of they only show half of the parts.
Thanks.
Weber fast idle
Weber fast idle
Re: Weber fast idle
Ask and you shall receive! Don't know if it's what you had in mind but here we go:
I can also post an exploded view of the carb, but I got to dig out my computer, if you do require it let me know, I'll dig it out put it in my phone and post(no internet, too far up in mountain, I use my phone)You do not have the required permissions to view the files attached to this post.
Labine R.
Labine R.
Re: Weber fast idle
Thanks for the pics. Unfortunately that isn't what I need. I forgot to write that I have an electric choke, a little bit of brain damage today.
