Valve clearance
- My tercel:: 87 (85 look) Tercel 4wd wagon, 85 Tercel wagon 4WD (Blå), 85 Tercel wagon 4WD Amfibious (Tvillingen) previous: 86 Tercel wagon 4WD
Valve clearance
hey, Blue have a little problem with valveticking. i have bought a feeler gauge set, but the clearance should be 0,18 and 0,28mm and the closest feeler gauge sizes is 0,20 and 0,30mm. so i wonder if its ok to just use those with 0,02mm wrong thikness?
Current: 87 Tercel 4wd wagon, 98 Toyota avensis 1,6 4a-fe, 85 Tercel wagon 4WD amfibious (tvillingen)
Former: 85 Tercel wagon 4WD (Blå), 86 Tercel wagon 4WD 87 Opel Corsa A 1.3, 84-88 Toyota Carina II 1.8, 93 Opel Vectra A 2.0 and 68 Mercedes-Benz E 200.
Re: Valve clearance
10% larger shouldn't be a problem, just set the valve lash a bit tight- so that the feeler gauge is a little hard to slide out and you should be fine. Be sure to set the valve lash while cold, otherwise you'll wind up with WAY too much clearance with a cold engine. While you're there, check that the half moon seal at the back of the head is sealed, they leak badly if not sealed into place.
'83 SR5-299K, -tRusty!
'85 SR5-265K--GOLD
'85 SR5-265K--GOLD
Re: Valve clearance
ok, nice to know. thanks
Re: Valve clearance
There are cold and there are hot clearances for valve lash. I'd try to find the right gauges if I was doing it...that way less noise and maybe you don't get to do it again.
